jccloutier Posted November 2, 2012 Share Posted November 2, 2012 I have a timeframe of 3400 frames, I am importing a .bip walk sequence that is only 300 frames. What could I do to move the 300 walking frames to the middle of my 3400 frames rather than at the beginning? Link to comment Share on other sites More sharing options...
cg_Butler Posted November 2, 2012 Share Posted November 2, 2012 The only way I know how to achieve this is to make sure you create key frames for the .bip file when you load it in. Then you have to select all the biped parts and then you can select all the keys and slide them using curve editor or dope sheet. The only problem is that by default a key frame is made for each biped part, for every frame, so file sizes can become large and slow if you have multiple bipeds. You can reduce the key frames through filtering when you load the biped, but doing this too much can make your biped look a bit strange when the motion is played back. It does work though and that the way i would do it. Link to comment Share on other sites More sharing options...
Josef Wienerroither Posted November 4, 2012 Share Posted November 4, 2012 Look into Motion Mixer Its similar to an NLE editing system for videos. You can load biped animations in it and arrrange them in time and even blend between them, trim them stretch them, etc... .. But be warned: for some strange reasone the developers made the UI work rather unintuitive, but i guess that's a general problem in many areas of the application Link to comment Share on other sites More sharing options...
