kennyho Posted November 3, 2012 Share Posted November 3, 2012 Hello all, Sorry quite new to this forum so, thanks for dropping by and go easy. I use Rhino v5.0 64bit with vray 1.5. My issue is that whenever I render, the resolution is locked to 565 x 423 pixels and below. I've tried overiding it to higher resolutions but it only renders it at that size. If i change the aspect ratio then the image size changes accordingly but never gets any bigger than the total area provided by the 565 x 423 resolution. The default rhino render works fine at any resolution. Hence, i'm wondering if there is an option that restricts rendering resolutions in vray. Previously it was working fine. This issue just popped up recently. I also installed a demo version of badger batch render recently. I've also tried reinstalling vray and uninstalling badger. But to no avail. Any help would be appreciated. Thanks in advance Link to comment Share on other sites More sharing options...
