Chris MacDonald Posted November 5, 2012 Share Posted November 5, 2012 I've rendered out a frame from max and saved it (and several render elements) into a 32bit float .exr file. I can access the RGB and Alpha channels but can't seem to get any of the others - specifically a multimatte. I'm using both Photoshop CS5 and After Effects CS5. Surely at least one of these supports .exr channels? Any help is much appreciated. Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted November 5, 2012 Share Posted November 5, 2012 Only Photoshop Extended can read the channels inside an EXR file... Link to comment Share on other sites More sharing options...
Chris MacDonald Posted November 6, 2012 Author Share Posted November 6, 2012 How? I can't seem to access them. Link to comment Share on other sites More sharing options...
anejo Posted November 6, 2012 Share Posted November 6, 2012 If you haven't already, you may need to install the following plugin. http://www.fnordware.com/ProEXR/ Link to comment Share on other sites More sharing options...
Valtiel Posted November 9, 2012 Share Posted November 9, 2012 These lovely folks have a tutorial on opening your passes to layers inside PS Extended. Link to comment Share on other sites More sharing options...
Rich O Posted November 12, 2012 Share Posted November 12, 2012 From memory, PS Extended can read EXR's, however you need the ProEXR plug-in to read the individual channels. Personally I think it's the easiest way to work with EXRs, otherwise you'd be looking at something like Nuke which is IMO beyond the needs of archviz. Link to comment Share on other sites More sharing options...
