Temporary Render Node
Jonathan
Is it possible to quickly 'hook up' another machine to my workstation to speed up render time? I have 2 i7 machines which are, most of the time, in separate locations however for certain projects I would like to combine the 2 for speedier rendering. Any advice appreciated.
If they are on the same network then it's easy enough but if they are in different physical locations, it complicates matters and is likely not worth the effort if you are only adding a machine or two.
I'd recommend Deadline as it's free for only a couple systems or looking into distributed rendering if you are using vray and mainly rendering still images.
