piotrek255 Posted November 12, 2012 Share Posted November 12, 2012 Hi, After a long time testing by myself i decided to ask for help. I tried many techniques like: using a hemisphere and vraylightmaterial putting hdr into vray dome light putting and removing the hdr from enviroment slot in the above examples my HDRi is a 50mb high quality 8k parking lot scene with defined sky point, i work in gamma 2.2 I tried tweaking a lot of settings with IM/LC/BF but i could not get a clean render, only brute force with 100 subdivs gave me clean render but the rendering time was absurd.... Is there a way to get a clean splotch free render with reasonable rendertimes? Link to comment Share on other sites More sharing options...
Ismael Posted November 12, 2012 Share Posted November 12, 2012 http://forums.cgarchitect.com/71909-v-ray-gi-hdri-splotches-blotches-spots.html Link to comment Share on other sites More sharing options...
piotrek255 Posted November 12, 2012 Author Share Posted November 12, 2012 thanks, but i tried it, it gave me some crazy rendertimes, the strange thing is i done the same setup on a different machine and i had no splotches, also, i didnt have to use so much samples to have clean results. Link to comment Share on other sites More sharing options...
Scott Schroeder Posted November 12, 2012 Share Posted November 12, 2012 Please post a screencap of all of your vray settings. Without them to use as a start, we can't really tell you where to fix things. Right now, we're like a blind man trying to solve a Rubix's Cube. Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted November 12, 2012 Share Posted November 12, 2012 The pics you attached look like the HDRI is in the GI Environment Override, which will give you a blotchy result. Make sure you have absolutely nothing in there (no environment whatsoever) and the HDRI is a VRayHDRI map in the VRayLight (dome). Link to comment Share on other sites More sharing options...
CliveG Posted November 12, 2012 Share Posted November 12, 2012 Try recent Viscorbel tut, this may help http://viscorbel.com Good luck Link to comment Share on other sites More sharing options...
