salf Posted September 25, 2004 Share Posted September 25, 2004 For some reason the VIZ snaps only works for some parts of the autocad based drawing, why? I mean, I drew in Autocad the floor plans of a house, then i file link or import it into VIZ, then Im gonna start creating the 3d model, with a spline, close it and the extrude it, for some reason, the VIZ snaps when drawing the spline, only works on some parts of the autocad drawing, thus making it impossible to draw it correctly, since its not snaping. Why is that?, i used to draw a wall using the autocad file as floor plan without problems, the VERTEX or END POINT snaps of VIZ will show up on every corner of the autocad drawing, but now, it only highlights some parts of the drawing while not others. Link to comment Share on other sites More sharing options...
mohamedberry Posted September 27, 2004 Share Posted September 27, 2004 i think there is a bug in VIZ when u import a CAD file containing lines, i mean if you make your walls poly lines instead of lines on AutoCAD, then import it to VIZ, it'll work... Link to comment Share on other sites More sharing options...
salf Posted September 29, 2004 Author Share Posted September 29, 2004 mmmmmmmmmmm................could it be?.......gonna check that...thanks! Link to comment Share on other sites More sharing options...
