leandrosilva Posted November 16, 2012 Share Posted November 16, 2012 Hello cgarchitect users. i just want to spread that Vray-RT is now full working with AMD HD7950! the drivers are catalyst 12.10. See yah! Link to comment Share on other sites More sharing options...
Dimitris Tolios Posted November 17, 2012 Share Posted November 17, 2012 I've contacted Vlado, the person who appears to be in charge of the VRay RT GPU forums @ Chaosgroup, and that's his response: vlado said: We did a quick test here with the 12.10 drivers; the 7970 card worked for simple tests with not bad performance for the official 2.30 builds, but video driver crashed for more complicated scenes. The 5970 card didn't work at all. Best regards, Vlado Wish ppl willing to do their own tests with 7950s and 7970s to give it a try and provide us with feedback on the situation. Thanks a lot. Link to comment Share on other sites More sharing options...
leandrosilva Posted November 17, 2012 Author Share Posted November 17, 2012 vray-rt working with Asus HD 7950 3GB: Link to comment Share on other sites More sharing options...
Valtiel Posted December 1, 2012 Share Posted December 1, 2012 (edited) Sadly, not so lucky on this end. From what I've been reading on the topic, there's a chance 12.11 intends to resolve the RT issue. So far I've only been getting different errors with the current beta of it. This simple scene with 2 teapots, 2 lights, and a plane on my XFX 7950 dual fan model running 12.10 and the latest VRay builds I get a driver crash and reset. The rt server and Max (Design 2011) don't hang or freeze but remain "waiting for image" indefinitely. The CL client works fine when I only try to use my X6 1100T as a device without the Tahiti Pro card but then I might as well run it in CPU mode. Fingers crossed for 12.11 Edited December 1, 2012 by Valtiel adding max version details Link to comment Share on other sites More sharing options...
Dimitris Tolios Posted December 1, 2012 Share Posted December 1, 2012 Thanks for the input in the thread. Hopefully compatibility will be improved and issues resolved with all AMD cards. Anyone with time and patience to contribute their trials, are more than welcome to inform us. Link to comment Share on other sites More sharing options...
peterkiralj Posted December 1, 2012 Share Posted December 1, 2012 (edited) Hi! I have a Sapphire HD 7950 and i'm trying to get the GPU to render, but am having no luck. I've installed the catalyst 12.10 drivers and it still didn't list the card in the 'Select openCL devices for Vray RT' menu, just the CPU. I don't really know where to go from here, so if anyone could offer some direction, I would gladly keep testing. Edit: - Ok, i figured it out. In the list, Tahiti is actually the GPU. I've ha d Nvidia cards till now and was not familiar with AMD hardware. To edit the list, you have to run it as administrator. - Vray RT can not render Vray lights, planes or anything really. When trying, I had the same result as Riley, crashing drivers. - I got it to work with omni and other simple light setups, but the speed wasn't much greater then the CPU+vray.adv setup. I think it was actually slower, but didn't note the actual rendering times. I will do some more testing later, but that's all for now. Edited December 2, 2012 by peterkiralj Link to comment Share on other sites More sharing options...
Valtiel Posted December 5, 2012 Share Posted December 5, 2012 (edited) I just tried with the newest Beta of 12.11 and it's working for me now! Both on my test scene (with V-Ray area lights) and a more complicated scene for a job I'm working on. A bit slow to launch when I first ran it but that's to be expected. It now launches immediately and performs quite well. This is fantastic I suggest everyone still struggling to get their 7950 cards working to try the new beta. Edited December 5, 2012 by Valtiel Link to comment Share on other sites More sharing options...
peterkiralj Posted December 6, 2012 Share Posted December 6, 2012 Tried it and works:) Link to comment Share on other sites More sharing options...
Valtiel Posted December 8, 2012 Share Posted December 8, 2012 Peter, are you getting viewport issues with the new drivers? I'm getting the infamous undrawn vertex dots syndrome on both spline and editable poly objects in DX9.0 mode and the traditional fixes aren't working. DX10 (which I understand should be avoided anyways on AMD cards) shows the verts but also every backfacing edge through forefacing polys. OpenGL's just crawling in the framerate. >_ Anyone else getting this with the newest beta? Link to comment Share on other sites More sharing options...
peterkiralj Posted December 9, 2012 Share Posted December 9, 2012 Hey! I have had no viewport issues so far using Nitrous and DX 11. I tested OpenGL and Nitrous on a scene with 4mil. polys and OpenGL is almost impossible to work with, while Nitrous is ~20fps on realistic+edged faces,~30 for realistic and ~35 for wireframe. The activeshade and production render still does not support Vray planes and some materials. Specifically, it does on objects made from 'nothing', but on parametric objects (windows), it just renders vray+bitmap materials as black. Link to comment Share on other sites More sharing options...
Dimitris Tolios Posted December 10, 2012 Share Posted December 10, 2012 peterkiralj said: Hey! I have had no viewport issues so far using Nitrous and DX 11. I tested OpenGL and Nitrous on a scene with 4mil. polys and OpenGL is almost impossible to work with, while Nitrous is ~20fps on realistic+edged faces,~30 for realistic and ~35 for wireframe. The activeshade and production render still does not support Vray planes and some materials. Specifically, it does on objects made from 'nothing', but on parametric objects (windows), it just renders vray+bitmap materials as black. The Vray RT GPU limitations are because of the program itself, and present when using either nVidia or AMD cards. Thus it is important for all of us aspired GPU-for-production users to understand the limitations before investing tons of cash for powerful cards etc. Link to comment Share on other sites More sharing options...
peterkiralj Posted December 11, 2012 Share Posted December 11, 2012 Interesting, I thought this was a driver limitation. I researched quite a bit before buying the new card, but haven't come up with this. Obviously, I am still learning this RT stuff. Do you maybe have any article/review where i could find this kind of info? Link to comment Share on other sites More sharing options...
abaskamal2 Posted December 21, 2012 Share Posted December 21, 2012 peterkiralj said: Hey! I have had no viewport issues so far using Nitrous and DX 11. I tested OpenGL and Nitrous on a scene with 4mil. polys and OpenGL is almost impossible to work with, while Nitrous is ~20fps on realistic+edged faces,~30 for realistic and ~35 for wireframe. The activeshade and production render still does not support Vray planes and some materials. Specifically, it does on objects made from 'nothing', but on parametric objects (windows), it just renders vray+bitmap materials as black. Hi Peter, What 3dsMax version did you use to get these FPS numbers? I tried my Sapphire HD 7950 Vapor X Boost with Nitrous on 3dsMax 2013 to no avail. Ta. Link to comment Share on other sites More sharing options...
a-max Posted December 24, 2012 Share Posted December 24, 2012 Hey guys, I've ordered a Gigabyte 7950 graphic card,but was out of stock till Thursday so I was wondering, before I confirm my purchase: 1.how does the 7950 perform on complex scene (over 1 mil polys) with vray RT? 2.could you provide some results regarding how fast does it render? 3 Did you guys ran into any more problems with it? 4.By any chance did you try the latest AMD beta 11 drivers, any performance gain/issues solved? Had an nvidia card before but seeing the amazing AMD luxmark Open Cl scores + the fact the latest nvidia cards are somehow "crippled" made me want to switch, however at this time I'm a little concerned regarding if I should really go with an 7950 or a 660ti since there are no benchmarks anywhere regarding Vray RT or viewport performance, I know since I've been searching for 2 weeks and nothing. Could you guys please get the test scene from the Vray forums and do some test renders since there's a whole thread with people waiting for some results. Vray rt test scene: http://www.chaosgroup.com/forums/vbulletin/showthread.php?52400-test-scene Vray rt 7970 thread: http://www.chaosgroup.com/forums/vbulletin/showthread.php?67028-amd-7970-anybody Thank you! Link to comment Share on other sites More sharing options...
peterkiralj Posted December 27, 2012 Share Posted December 27, 2012 (edited) Abas: strange, mine is also max 2013. Just to clarify, I am using the 12.11 beta drivers, if that makes a difference. Edited December 27, 2012 by peterkiralj Link to comment Share on other sites More sharing options...
Valtiel Posted January 15, 2013 Share Posted January 15, 2013 For the interest of anyone else using this card, I ran the benchmark scene available on Chaos Group's forums (for some reason my account seems to be unable to post there) but my result so far is abysmal. 16m 40.6s on a single 7950. I had let the scene go through the extensive loading time in a previous click of the activeshade button so this began rendering immediately. This is in compares to some ~2m times reported by people using NVIDIA cards. I had a second instance of max open plus this browser but nothing was really applying another load to the card so I don't think much retesting will yield better results. Knowing the raw compute of the 7000 series is good, I suspect this is still a driver limitation though the client is finally functional under 12.11 beta. Link to comment Share on other sites More sharing options...
leandrosilva Posted January 26, 2013 Author Share Posted January 26, 2013 Hi guys. I recently tested the 13.1 drivers and the Vray rt continues to work perfectly with a complex 3ds scene. Very good! Link to comment Share on other sites More sharing options...
Valtiel Posted January 26, 2013 Share Posted January 26, 2013 Hi Shadowzone. What kind of times are you getting on the benchmark scene? I'm wondering if maybe the poor results I'm getting are specific to my setup (almost hoping they are) Link to comment Share on other sites More sharing options...
leandrosilva Posted January 26, 2013 Author Share Posted January 26, 2013 give me the link for test scene and what i should do? Link to comment Share on other sites More sharing options...
Valtiel Posted January 27, 2013 Share Posted January 27, 2013 http://www.chaosgroup.com/forums/vbulletin/showthread.php?52400-test-scene The posts are arranged in reverse chronological order compared to ones like this, so the newest posts are on the first page there. Vlado's posted the scene on either the earliest or second-earliest pages. It's set up already for you to hit activeshade when you open it and will halt/finish once 512 rays/pixel have been cast. The time it takes to hit that sampling rate is your benchmark score, the quicker the better. Link to comment Share on other sites More sharing options...
leandrosilva Posted January 27, 2013 Author Share Posted January 27, 2013 Hey Riley! I made the vray test scene that you indicated. Results with 13.1 drivers, Vray Rt 2.30.02, i7 3930k (without any overclocking) and 32GB Memory 1866mhrz: OpenCL (single kernel) - 5.29min Cuda (single kernel) - 32.18min CPU - 31.36min I'm surprise with this results... in the three examples..the scene always present the noisy effect and take some time to load and render..dont know if it was from this test scene or if it happening with all complex scenes. personally i just use the vray rt (in open cl mode) for light balance the scenes..with generic vray material, so the work with rt is very rapid and good and dont present the noise effect...for mapping and textures i prefer production render with low custom settings. (sorry for dont respond your last email message..it has gone automatically to trash :/) Link to comment Share on other sites More sharing options...
Valtiel Posted January 28, 2013 Share Posted January 28, 2013 That's alright. The benchmark's not intended to output a clean final image. The results are strange indeed, though. You are using a retail 7950, yes? Which version of Max? because my results are yielding three times that turnover time. Link to comment Share on other sites More sharing options...
leandrosilva Posted January 28, 2013 Author Share Posted January 28, 2013 the graphich card is Asus Radeon HD7950 DCII Top 3GB. 3ds Max DEsign 2013 64bits Link to comment Share on other sites More sharing options...
Valtiel Posted January 29, 2013 Share Posted January 29, 2013 Hmm. Maybe it's a Max Design 2011 thing. I'll be picking up 2013 soon though so I'll give it another whirl then. Thanks for going through that, shadowzone! Cheers! Link to comment Share on other sites More sharing options...
leandrosilva Posted January 29, 2013 Author Share Posted January 29, 2013 Ok. If someone that can run the test and post the results will be great! cheers Riley Link to comment Share on other sites More sharing options...
