sirmartin Posted November 21, 2012 Share Posted November 21, 2012 Hi! I´m having some issues, please help. I´ve a scene of one single object where i want a matte reflection without shadows, what to do? i cant get the matte reflection to work without shadows, maby it´s impossible, i dont know Best regards Martin Link to comment Share on other sites More sharing options...
cg_Butler Posted November 21, 2012 Share Posted November 21, 2012 (edited) Can you upload your scene to dropbox or somewhere where someone can have a look? Alternatively upload a picture to help explain what you need exactly. Edited November 21, 2012 by cg_Butler Link to comment Share on other sites More sharing options...
John Dollus Posted November 21, 2012 Share Posted November 21, 2012 Turn off shadow casting in the object properties? Link to comment Share on other sites More sharing options...
sirmartin Posted November 21, 2012 Author Share Posted November 21, 2012 I´ve tried that, not the result i wanted dough. Thanks Martin Link to comment Share on other sites More sharing options...
cg_Butler Posted November 21, 2012 Share Posted November 21, 2012 Do you just want an in image of the reflections on the object? Link to comment Share on other sites More sharing options...
sirmartin Posted November 21, 2012 Author Share Posted November 21, 2012 I want the reflection in a separate pass and the object the same way, but i can only manage to do that if i leave the shadow check box be. Link to comment Share on other sites More sharing options...
cg_Butler Posted November 21, 2012 Share Posted November 21, 2012 If you add in a VrayRAWReflection element and save that then you will have what you need. If I understand you correctly. Have a look at these examples Render Elements. Is the Reflection only the sort of this you are after? Link to comment Share on other sites More sharing options...
sirmartin Posted November 21, 2012 Author Share Posted November 21, 2012 Tks, ill try that Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted November 21, 2012 Share Posted November 21, 2012 You need to use the VrayDirt Map. It's a lengthy process to describe, but ths link seems to sum it up well: http://www.workshop.mintviz.com/tutorials/matte-shadow-and-reflection-using-v-ray-2-0/ Link to comment Share on other sites More sharing options...
