shaheenshy Posted November 29, 2012 Share Posted November 29, 2012 i`m working with max 2012 and mental ray render engine , many times i have the attached error , then mental ray crashes and shutdown pleas help Link to comment Share on other sites More sharing options...
Scott Schroeder Posted November 29, 2012 Share Posted November 29, 2012 What are you trying to render? What is in your scene? What are your settings? Where did you get this file? Are you sure that everything in the file is 100% compatible with MR? The more descriptive you are, the more help you will get. It is either a memory issue, an incompatible object/material/light, or a bad render setting. Or all 3. Are you using BSP or BSP2 in your settings? Link to comment Share on other sites More sharing options...
shaheenshy Posted November 29, 2012 Author Share Posted November 29, 2012 thanks Mr.Scott for your kindly reply this error appears to me with several files , i don`t know why ?!! i also tried both Bsb and Bsb2 and i got the same message , the materials are several too !!!!! any help? Link to comment Share on other sites More sharing options...
John Dollus Posted November 29, 2012 Share Posted November 29, 2012 Check for software updates/service packs. 2012 mental ray version is 3.9.3.14 and yours is older for some reason Link to comment Share on other sites More sharing options...
Scott Schroeder Posted November 29, 2012 Share Posted November 29, 2012 John Dollus said: Check for software updates/service packs. 2012 mental ray version is 3.9.3.14 and yours is older for some reason Now that I look at it, that's not even the Max 2012 icon at the bottom or at the top of his screen cap. This looks like 2010. The OP may be having compatibility issues. Link to comment Share on other sites More sharing options...
shaheenshy Posted November 30, 2012 Author Share Posted November 30, 2012 thanks all , updates solved the problem Link to comment Share on other sites More sharing options...
