Keen098 Posted December 2, 2012 Share Posted December 2, 2012 Studio/Institution: PrivatGenre: OtherSoftware: 3ds MAX 2013 and VrayDescription: Simple white living-room. Any ideas to make it look more realistic? I'm not really satisfied with my work. Thanks! Software 3DS MAX 2013 VRAY Link to comment Share on other sites More sharing options...
aaronmolina Posted December 3, 2012 Share Posted December 3, 2012 (edited) Here's a few tips: 1 it doesn't look like there are any reflection maps on the floors. 2 that rug looks a little too thick 3 the correct lighting will add to the realism 4 this is my personal oppinion , but the sofa looks a little too thin to be that round, or just add sharper edges o the sides. Sofas are usually flatter on the sides. 5 also for aesthetic purposes, the sofa probably shouldn,'t be the exact same color as the walls. 6 and it's kinda hard to tell what's going on at the top of the steps. You have a good start. After you get your raw render, you should look at different post production techniques. Edited December 3, 2012 by aaronmolina Link to comment Share on other sites More sharing options...
salvador Posted December 3, 2012 Share Posted December 3, 2012 check your white balance. Walls look yellowish from here. Also, seems like there is a single light source. Try some more contrasting light sources from the exterior to the interior. Link to comment Share on other sites More sharing options...
Keen098 Posted December 6, 2012 Author Share Posted December 6, 2012 Thanks for the answers! I fix some of the suggested points, the result is much more better! I will post tomorrow the new render, hope to get again some good suggestions. Link to comment Share on other sites More sharing options...
avaross Posted May 31, 2013 Share Posted May 31, 2013 This might be too simple/stupid a suggestion, but what about adding some wall art? That will definitely make it look more realistic. Otherwise, very nice job. I'm impressed. Link to comment Share on other sites More sharing options...
