conrad5 Posted December 4, 2012 Share Posted December 4, 2012 I have a problem with transparency rendering. At first i thought its a problem with my self-made material, but I downloaded perforated steel material from the internet and the problem appeared again. My sketchup doesn't render full transparency and leaves glass like material in places where nothing should be. I have attached my rendered material and original material image. I hope anyone of you can help me. Thank in advance for your help. Link to comment Share on other sites More sharing options...
M V Posted December 17, 2012 Share Posted December 17, 2012 If its a PNG, check the file to make sure the transparent parts are really transparent. If you are using a alpha map, I would just convert that texture into a PNG. That way, you will also see the transparency in SU. Link to comment Share on other sites More sharing options...
