dande Posted December 4, 2012 Share Posted December 4, 2012 I have got the error "Application failed to return a video frame" I have narrowed it down to a cross transition. If I remove the cross transition at that point it exports fine. Put a cross transition in it crashes. I notice that the cross transition in question has diagonal lines through it. Thanks Link to comment Share on other sites More sharing options...
easy3dsource Posted December 5, 2012 Share Posted December 5, 2012 I'm assuming the footage you're using for that part of the edit contains an image sequence? If that's the case, it could be that you're missing the frame at that point in the sequence. Link to comment Share on other sites More sharing options...
dande Posted December 5, 2012 Author Share Posted December 5, 2012 Thanks for your reply Alexander. It exports fine if I remove the transition. It's only when I have a transition at that point. I have a number of transitions in the timeline it just appears to be this one. Funny enough this transition has diagnal lines theough it like hatching where the others don't Link to comment Share on other sites More sharing options...
