Roodogg Posted December 5, 2012 Share Posted December 5, 2012 Hi guys. sorry if this has been asked before - couldn't find it though. Very simply, my Vray Envoronment fog isn't accounting for my alpha maps in the vraymtl opacity slot. This really sucks. thanks in advance for help. Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted December 5, 2012 Share Posted December 5, 2012 I'm not surprised that you are having trouble with fog. It tends to screw everything up for post production. You would likely do well to render you image straight and then apply a black light materiel, or just general matte material and render the fog. Fog is a good tool, but a pain to work with when it gets baked in. Link to comment Share on other sites More sharing options...
RyderSK Posted December 5, 2012 Share Posted December 5, 2012 Vray takes opacity into account, see my example of VrayEnvironmentPass featuring opacity mapped leaves. Also, make sure your opacity is strictly black/white, and with set filtering "off" (instead of pyramide or sum). Make your material check under refraction properties "affect shadows" and "affect all channels". Try again to see if it helps. From head, nothing comes to my mind why this would troubleshoot you. Link to comment Share on other sites More sharing options...
RyderSK Posted December 5, 2012 Share Posted December 5, 2012 CoreyMBeaulieu said: I'm not surprised that you are having trouble with fog. It tends to screw everything up for post production. You would likely do well to render you image straight and then apply a black light materiel, or just general matte material and render the fog. Fog is a good tool, but a pain to work with when it gets baked in. Yes, unless you feel you must, never render baked in fog. Apply BlackLightMaterial to everything EXCEPT for the opacity mapped leaves. Apply similar material (blacklightmtl) but with opacitymap. This will render very fast your correct fog pass in VrayEnvironmentPass. Best applying as "screen" layer in post. Link to comment Share on other sites More sharing options...
