2D Noise map
Nic H
http://www.scriptspot.com/3ds-max/scripts/proceduraltexturebaker
tried this to bake it out to 2d - but it wont do image sequences
i remember years ago a '2d noise' on scriptspot that was also loopable - cant find it anymore
maybe
_ _ _
edit - seems this isnt possible
will just do it in fusion and make an image sequence from there. probably easier but means i can sync it to animated phase rates
Edited by nicnic
You don't need a script to render out a map from the material editor of max, all you do is open your noise map, make sure Show End Result is not highlighted, then right click on the preview in the editor and click Render Map...
If you've animated the Phase in the bump map, then the render will render the sequence.
Also try this http://www.softpedia.com/get/Multimedia/Graphic/Graphic-Others/Caustics-Generator.shtml I've used this in the past, don't know if it's quite what you're after, but it works well for faking caustics on the bottom on the ocean.
Dean
