Wrender Posted December 21, 2012 Share Posted December 21, 2012 Here's the problem: I've set up a scene using a MR Sun and Skylight using a EXR/HDR in the Environment slot. When I use an EXR file everything is fantastic. I'm able to lower the output amount down in the material editor, adjust the physical scale to unitless, and get the exposure value set. Rendering looks great! HOWEVER, I would like to do this same thing with an HDR file. In my case above I'm using the exact same image but in a HDR format. I would think you would pop it in and the settings would be the same. But when I do this, lowering the output amount makes the image dull and desaturated, rather than just bringing the intensity down as in the exr file. So when I render, I just get a muddy grey sky and background image....why why why? If anybody could shed some light (punny right?) on the issue I would appreciate it! Link to comment Share on other sites More sharing options...
BrianKitts Posted December 21, 2012 Share Posted December 21, 2012 Shouldn't make a difference. did you make the HDR yourself from the EXR? I would open up your HDR file in HDRshop and check to see that all your exposure levels are intact and that it didn't lose it's dynamic range in the conversion. Link to comment Share on other sites More sharing options...
Matt McDonald Posted December 26, 2012 Share Posted December 26, 2012 could it be a gamma issue? I have this feeling that I remember reading something about one format or the other handling gamma differently than most files. Link to comment Share on other sites More sharing options...
