How to fix vray sketchup final render?
  • 2 months later...
Most likely its your displacement. Try reducing the subdivs, increase the edge length, and also up your system memory limit in your options. You are probably just running out of memory. If all of this fails, I would use displacement cautiously. You are stuck in a 32 bit environment with SU. Most if the time, a bump will do the job.
  • 1 month later...
