alexserg Posted January 7, 2013 Share Posted January 7, 2013 Hello, The image on the left is with the ghost shapes showing up through the window. The one on the right is how it should look. I have used Walls for the creating of the room and sliding windows. After a while the ghost rectangles appear. If i change any of the parameters of the window they disappear for a few minutes and then reappear. any ideas what may be causing this and how to fix it ? Thank you Link to comment Share on other sites More sharing options...
Chris MacDonald Posted January 7, 2013 Share Posted January 7, 2013 I get this too, and it looks like z-fighting even if there is none. I have come to the conclusion that it's just the max viewport being absolutely shit - it's needed an overhaul for a long time now. Use orthographic mode if you have to. Link to comment Share on other sites More sharing options...
shwetajaiswal Posted January 7, 2013 Share Posted January 7, 2013 Hi,I am shweta and a fresher in 3d field.I am interested 3dsmax.maya and also vray.I want to explore my knowledge in this field specially architectural field. Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted January 7, 2013 Share Posted January 7, 2013 It could be a viewport thing, but it could also be an AEC Walls thing. I don't use them and would strongly encourage you not to, but just like a slice plane, when your window cuts into your wall, Max has to rapidly regenerate your geometry in a new way. As you move the parameters around, Max struggles to make new polygons and resolve them accurately. Slice plane has the option of recreating Quads or Tris (Tris usually work best), even still. If you need a wall and a window, I suggest using a line, extrude, shell method. Place vertecies where windows should go and then add an edit poly atop. Connecting edged and then using the bridge function can create windows and the modifier stack will allow you to continue to change the thickness of the walls. Link to comment Share on other sites More sharing options...
Chris MacDonald Posted January 7, 2013 Share Posted January 7, 2013 Hi,I am shweta and a fresher in 3d field.I am interested 3dsmax.maya and also vray.I want to explore my knowledge in this field specially architectural field. -_____- Link to comment Share on other sites More sharing options...
rhlkvr15 Posted January 14, 2013 Share Posted January 14, 2013 Gr8 place to start with shweta..... Link to comment Share on other sites More sharing options...
Nic H Posted January 16, 2013 Share Posted January 16, 2013 that is crappy geometry dont use the AEC objects they dont work. Link to comment Share on other sites More sharing options...
alias_marks Posted January 17, 2013 Share Posted January 17, 2013 Sometimes if you have geometry way off the origin, like a couple miles, max starts to act really wierd with geometry.. If ditching AEC objects doesn't work might double check to make sure everything is somewhat close to the origin.. Link to comment Share on other sites More sharing options...
