c0nfused2 Posted January 8, 2013 Share Posted January 8, 2013 Hi, I was wondering how do I render a selected object only like in mental ray but in Vray. While it still receives lighting reflection and the scene aroudn the particular object. Thank you. Link to comment Share on other sites More sharing options...
Chris MacDonald Posted January 8, 2013 Share Posted January 8, 2013 Sadly this is one area of VRay where I have to concede it isn't as good as mental rays "render subset" feature, however it has been requested on the chaos group forums. You'll have to find a work-around, of which there are probably many. You may want to (temporarily) switch everything elses object properties to invisible to render camera, but still visible in reflections/shadows? Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted January 8, 2013 Share Posted January 8, 2013 Use a Vray Material Wrapper to create a Matte for objects that you don't want to see. Tick Matte, Shadows, Affect Alpha, and switch alpha contribution to -1.0. in the Base material node place an all black, non reflective material. With this you can set the material override in the global render settings and the exclude the item or items that you want to render. In the end you will have a pass tat is only an object or two with shadows and the reflection of the scene on them, but nothing else. Link to comment Share on other sites More sharing options...
c0nfused2 Posted January 8, 2013 Author Share Posted January 8, 2013 thank you for the responses and the info =) Link to comment Share on other sites More sharing options...
