EXPERTS, please review this configuration!!! (Thanks)
I would really appreciate your help!!
What do you think of this combo:
Case: ATX NOX CoolBay Tower
Motherboard: ASRock 1155 Z77 PRO4-M
Processor: Intel Core I7 - 3770 - 3.4 GHz
Memory: 8 GB DDR 3 Ram (2 x 4gb) - PC 1333
Hard Disk: 240GB Extreme SSD HDD
Graphic Card: Geforce 660 GTX - 2GB - PCIX
Optical Drive 1: LG/Philips/Pioneer 16x double layer
Miscellaneous 1: 900W PSU
Miscellaneous 2: 8 GB DDR 3 Ram (2 x 4gb) - PC 1333
Miscellaneous 3: 2 Terabyte Sata Hardrive
All in all it is a cookie cutter setup. Nothing wrong with it. Some comments
PSU: 900W PSU is over-the-top-over-kill for your configuration.
Your system under full load won't be pulling more than 350W off the wall at full CPU/GPU load, which is very very rare to happen. When rendering with your CPU etc, I would expect less than 250W.
A 650W would be more than enough, with headroom for adding a second GPU in the future (or dual 79xx etc just as well). Future GPUs and CPUs will be more power efficient also, so the 900W is overkill for any single GPU system unless you are planning on a system with more than 2x GPUs for gaming or GPU rendering, or an overclocked 6-core s2011 with 2 or more cards (still probably doable with a good 650W and 2x 6xx nvidia cards).
Get a 80+ Gold or equiv. rated 650-700W and you are more than safe, with the PSU operating at the sweet spot between 50-60% load for max efficiency.
SSD: Sandisk or w/e makes good SSDs, but the fastest + most reliable atm are the latest drives from Samsung (840 Pro), OCZ Vertex 4/Vortex and Plextor M5. If I wanted something cheaper, i would opt for Crucial m4 or Samsung 830 that are phased out now, yet hold pretty good performance along with the best reliability record.
RAM: get 2x8GB, preferably 1600 or 1866 speed. The price benefits from 1333 are minimal, while speed % penalty is not. The board will have 4x dimms, so getting 4x4GB sticks is not wise: you are ruling yourself out of upgrading to 32GB without wasting your initial investment.
Edited by dtolios
  • 2 weeks later...
