Jason Matthews Posted January 18, 2013 Share Posted January 18, 2013 Hey all, I am pre-calculating my LC for an animation of about 2000 frames to be used with a pre-calculated IR Map. I setup the LC to render in fly-through mode and do all the normal settings such as "do not render final". The odd thing is that it renders the LC for the first frame and then it goes through the 2000 frames and does a rendering prepass. Why is that? Shouldn't it be running the LC for each frame instead? I guess I really never paid attention before. Is this normal? Link to comment Share on other sites More sharing options...
waikitgarychin Posted January 19, 2013 Share Posted January 19, 2013 It is normal, but LC calculate is not working for animated object Link to comment Share on other sites More sharing options...
Jason Matthews Posted January 22, 2013 Author Share Posted January 22, 2013 Thanks. I did find that on one material I checked interpolate which killed my LC calc time for some reason. Link to comment Share on other sites More sharing options...
cg_Butler Posted January 22, 2013 Share Posted January 22, 2013 (edited) It's not normal.......the other chap is wrong. I read your first post, was going to reply straight away with that answer that you have Interpolation on a material! So well done for finding it yourself. With this on, it will do a prepass for that reflection /refraction of any material it is on. It can improve the quality of glossy materials, at the expense of longer rendering times due to the extra calculation. Here is a link Edited January 22, 2013 by cg_Butler Link to comment Share on other sites More sharing options...
Jason Matthews Posted January 22, 2013 Author Share Posted January 22, 2013 That's exactly where I read it. I put a vray material in my scene from a vray materials website and forgot to uncheck the box. Thanks for the reply. Jason Matthews Link to comment Share on other sites More sharing options...
