spardhaangra Posted January 19, 2013 Share Posted January 19, 2013 I am a second year architecture student planning to buy a new laptop. My hear is set on Asus K55VM-SX086D (3rd Gen Ci7/ 8GB/ 1TB/ DOS/ 2GB Graph) Here are the technical specifications: Processor Core i7 (3rd Generation) Variant 3610QM Chipset Mobile Intel HM76 Express Brand Intel Clock Speed 2.3 GHz With Turbo Boost Upto 3.3 GHz Cache 6 MB MEMORY Expandable Memory Upto 8 GB Memory Slots 2 (Unused Slot - 0) System Memory 8 GB DDR3 STORAGE Hardware Interface SATA RPM 5400 HDD Capacity 1 TB OPTICAL DISK DRIVE Read/Write Speed 8x Optical Drive DVD RW SuperMulti Drive with Dual Layer Support PLATFORM Operating System Free DOS Architecture 64-bit DISPLAY Screen Size 15.6 inch Resolution 1366 x 768 Pixel Screen Type Widescreen BrightView LED-backlit Display GRAPHICS Dedicated Graphics Memory Type DDR3 Dedicated Graphics Memory Capacity 2 GB Graphic Processor NVIDIA GeForce GT 630M INPUT Web Camera 0.3 Megapixel Pointer Device Touchpad Keyboard Seamless Chiclet Keyboard AUDIO Internal Mic Yes Speakers Altec Lansing COMMUNICATION Ethernet 10/100/1000 Base T Wireless LAN IEEE 802.11b/g/n Bluetooth v4.0 POWER Battery Backup Upto 3 hours Power Supply 65 W AC Adapter Battery Cell 6 cell PORTS/SLOTS USB Port 1 x USB 2.0, 2 X USB 3.0 RJ11 No Mic In Yes RJ45 LAN Yes HDMI Port Yes VGA Port Yes Multi Card Slot Yes MACHINE DIMENSIONS Weight 2.6 kg Dimension 378 x 253 x 34.9 mm Please tell me if its a good buy or not Link to comment Share on other sites More sharing options...
Jason Matthews Posted January 22, 2013 Share Posted January 22, 2013 What are you doing with it? Link to comment Share on other sites More sharing options...
spardhaangra Posted January 22, 2013 Author Share Posted January 22, 2013 What are you doing with it? I would be majorly using it for CAD, Photoshop and Studio Max 3D.. Link to comment Share on other sites More sharing options...
Jason Matthews Posted January 22, 2013 Share Posted January 22, 2013 It's probably fine then. I like to have some head room for RAM and 8gb just doesn't cut it IMO. If you were doing Revit I would say you will be fine util your model gets above 30Mb. Processor is good and the video card is OK. Jason Matthews Link to comment Share on other sites More sharing options...
Dimitris Tolios Posted January 22, 2013 Share Posted January 22, 2013 (edited) It is a mediocre buy because of the 768p screen. It is just too small imho. I have worked on a 768p laptop for a year. It was pretty fast for its time, yet the limited screen real estate really becomes hard to work with when in CAD or illustrator etc you dealing with extended toolbards. The interface eats up all the space, and you are left with a small keyhole sized viewport to work with. If you have to go to a 17" to get 900-1080p, do it. If you have to pay a bit more to get a 15" 900-1080p, it does worth it. Edited January 22, 2013 by dtolios Link to comment Share on other sites More sharing options...
artmaknev Posted January 27, 2013 Share Posted January 27, 2013 These two things are not good for 3ds max and CAD... the screen is indeed to small to work around in max with all the toolbars open, also that graphic card is really slow, no matter how many gigs it has, I think the clock speed is too slow, only good for watching movies, spending extra $300-400 upgrading these two items will be worth it in the longer run: Resolution 1366 x 768 Pixel Graphic Processor NVIDIA GeForce GT 630M Link to comment Share on other sites More sharing options...
Jason Matthews Posted January 27, 2013 Share Posted January 27, 2013 When I was in school I ran CAD and Max on an 850mhz P2 with a 15" screen and 8mb graphics card and had no problems. You should learn the AutoCAD keystrokes. Do that you are not dependent on all of the toolbars. Close the toolbars and you get your screen real estate back. I know that money is tight as a student and mobility is key especially when working on your project in the middle of arch history. Jason Matthews Link to comment Share on other sites More sharing options...
