Justin Hunt Posted January 23, 2013 Share Posted January 23, 2013 Sometimes some of the geometry becomes corrupted and scrambles the geometry into an absolute mess. At first I thought it was the actual geometry being messed up so I'd delete and recreate it. I have since discovered that it is just the display that is corrupted as it renders fine. Also if I go into sub-object mode the verticies are where they should be. Interestingly once I exit sub-object mode the object is now correctly displayed. I have the latest PU6 installed and my graphics drivers are up to date. I am using Nitrous with a Quadro FX 1800 graphics card. Anyone else come across this??? Thanks Link to comment Share on other sites More sharing options...
Scott Schroeder Posted January 24, 2013 Share Posted January 24, 2013 I get a similar thing every so often when switching back and forth from wireframe to realistic in Nitrous. A quick restart solves it but it's a pain in the ass. Does yours go away after a restart? If so, it's probably a bug in nitrous. Link to comment Share on other sites More sharing options...
Justin Hunt Posted January 24, 2013 Author Share Posted January 24, 2013 Up until today a restart wouldn't solve the issue. I only discovered the sub-object trick today Link to comment Share on other sites More sharing options...
salvador Posted January 24, 2013 Share Posted January 24, 2013 Direct 3D? It's a shame to stick to the old stuff when there's new things around, but what the heck, if it works. . . Link to comment Share on other sites More sharing options...
Scott Dombrowski Posted January 24, 2013 Share Posted January 24, 2013 I've had the same thing happen a few times too. I think a system reboot was required to clear it up. Max Design 2013 x64, PU6, Quadro FX 4800 on Windows 7. Link to comment Share on other sites More sharing options...
Paul Twyman Posted January 24, 2013 Share Posted January 24, 2013 Yeah, I have had this a couple of times too. On big scenes it can be hard to find the responsible object. I think I just merged the object from a previous version which solved it. Will defintely try the sub-object trick first next time though. Link to comment Share on other sites More sharing options...
