vladimirsitnik Posted January 25, 2013 Share Posted January 25, 2013 HI! In my scene apears some bright orange spots on render... anyone can help or knows what could be the problem? I will be very grateful to hear the answers ... I use a 3ds MAX 2011 and Vray 2.0 Link to comment Share on other sites More sharing options...
cg_Butler Posted January 25, 2013 Share Posted January 25, 2013 What software is the screen grab from? I've never seen this problem in VRay before but just check your base render.....before you are bringing it in to that software. Link to comment Share on other sites More sharing options...
vladimirsitnik Posted January 25, 2013 Author Share Posted January 25, 2013 Andy Butler : no!!! its a pure 3d render. Image in 3ds max looks same like this!!! Foundry Nuke software... Link to comment Share on other sites More sharing options...
Scott Schroeder Posted January 25, 2013 Share Posted January 25, 2013 See that it only seems to affect area that have shrubbery in them, I would look at that object and it's material. I'm betting on an incompatible or material with horrific settings. What happens when you render a gray vray material override? Do you still get it? If no, then it's your materials. If yes, then it's not a material and is either a light or geometry object. The very first step in vray troubleshooting to render the gray override pass if you get something like this. Remove the materials from the equation then go from there. Link to comment Share on other sites More sharing options...
cg_Butler Posted January 25, 2013 Share Posted January 25, 2013 Whatever it is, i've never experiencd it! Good tips though from Scott, so definitely start there. Also, if you right click in a max viewport and choose V-RAY Scene Converter, it will convert most but not all materials to vray materials. That might help too. Link to comment Share on other sites More sharing options...
vladimirsitnik Posted January 25, 2013 Author Share Posted January 25, 2013 i dont think so becouse if i make a crop render for example is ok... but in full resolution case 4096x1862 seams apers in random places at the random objets... but in any case i will try make a gray render... Link to comment Share on other sites More sharing options...
vladimirsitnik Posted January 25, 2013 Author Share Posted January 25, 2013 with gray vray material override ALL is fine... ((( clean render without any color seams... Link to comment Share on other sites More sharing options...
