Can anyone help me with adding a multiplier factor to an IES file?
jamierosssmith
G'day everyone,
Long-time reader/lurker, new member and first-time poster!
I'm simulating a workshop, with the intent of proposing a better lighting system. Unfortunately I cannot get IES files for the lights we currently have on site, but I've found an IES files which is very similar, but less powerful (250W vs. 400W HPS, 30,000lm vs. 48,000lm). I've read elsewhere that you can easily change the power of the emitter in the IES file, by adding a 'candela multiplier' line, or changing the first '1' to '1.6' (in this case). I've tried changing the one, and it doesn't work for decimals? If I change it to a 2, my software registers the light as a 60,000lm emitter, but if I change it to 1.6, it remains at 30,000.
Secondly, I've tried using a 3rd party application to edit the IES file, by stipulating that I want a 1.6 multiplier, but when I save the file, the actual IES code hasn't changed? I've found a step by step guide as to adding a multiplier for previous IESNA standards, but none for the IESNA LM-63-2002 standard, which I'm using.
Can anyone help?
Cheers!
The IES file is read by Max and all the editable information shows up as parameters in its properties panel, that's where you want to adjust how powerful the light is not in the .ies file. IDK where you found this code, it may have been the way to adjust the light many years ago before they were fully supported in Max, but that's not the way to do it now.
changing the multiplier in the ies file itself will not work for the program you are using. You will need to overide the actual lumen field in the ies file instead. not all programs use all of the data from the ies file spec.
You can also try asking on the lightup support forum as well.
