M V Posted February 4, 2013 Share Posted February 4, 2013 I am working on a project of a high end home in the Tudor style. I need to have several different patterns of brick in various stacked patterns like herringbone, etc. Is there a program that will make brick textures and make them in these types of configs? I came across Bricks n Tiles but it looks a little dated and I use Acme brick to get nice images of running and soldier courses but I am curious if there is something out there that will do wild patterns also. Link to comment Share on other sites More sharing options...
Scott Schroeder Posted February 4, 2013 Share Posted February 4, 2013 I usually bite the bullet and make the textures myself. I have a template that I use that has the grout and color variation already set up and all I need to do is add in the color. I created the template by creating the brick pattern in Max and rendering out a 4kx4k image that gives me easy masking tools for the grout and brick areas as well as different shades to control color variation if needed. Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted February 4, 2013 Share Posted February 4, 2013 I also bite the bullets several times with this, but there is some pretty good scripts/software around such, Bercon maps, mightytiles and vizpark walls & Tiles that can works for what you need. Link to comment Share on other sites More sharing options...
M V Posted February 5, 2013 Author Share Posted February 5, 2013 MightyTiles is perfect, except I am not using Max. I need something thats more of a texture generator that is standalone. Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted February 5, 2013 Share Posted February 5, 2013 I use Modo and cinema 4D too, so I guess Brick n Tiles is your best option, in MODO you have a random script that may work but not sure what is your workflow Link to comment Share on other sites More sharing options...
xEndlessxUrbiax Posted February 5, 2013 Share Posted February 5, 2013 I use Acme Brick as well and make my own patterns if it's flemish, english, herringbone, etc... I'm gonna have to try out MightyTiles and Brick n Tiles, thanks. Link to comment Share on other sites More sharing options...
M V Posted February 6, 2013 Author Share Posted February 6, 2013 I use Acme a lot. Its the best thing I have right now. How do you make herringbone patterns in their software though? Or do you take the textures and make your pattern in Photoshop? Link to comment Share on other sites More sharing options...
xEndlessxUrbiax Posted February 6, 2013 Share Posted February 6, 2013 I take those textures into photoshop to create any pattern not supported by Acme. Unfortunately that's anything besides a stack and running bond. Link to comment Share on other sites More sharing options...
