SKetchup Glass Walls in Max and Vray
Sketchrender
Sketchup file imported into Max (2012) and rendered with Vray.
Some of the walls in the models are 200mm thick glass.
If I put a vray glass material on it, it obviously will not render as a proper glass pane, as I normally make 20mm.
So with out re doing every single wall and reducing the thickness, is there a material setting for such items ?
Thank you
phil
200 mm is OK now VRay may read it as 2 single panels of glass instead a thick glass, but as Jason mentioned check the shadows options and play with the Index of Refraction, IOR, I would recommend un-lock the reflections from the refraction so you can adjust both as need it, but that will do.
IO refraction when close to 1 you get less distortion.
