remilanza Posted February 7, 2013 Share Posted February 7, 2013 (edited) Hi, I'm playing around with the expression controller, but there is something i don't understand. I'll explain the problem with a simple example. I have object A, B and C. On C I want an attribute that measures the distance between object A and B. So I add an expression controller to a custom attribute on C. I make 2 vector variables, PosA (connected to the postion of A) and PosB (position to B). In the expression I write "length(PosA-PosB)". So now, when I move A and B, my attribute shows me the distance between the two objects. BUT, if I link object A to a new object, and move this new object to move object A, the value on my distance attribute doesn't change! Is there a way around this problem? What happens to the "position value" of an object when it's linked to another object? (I've had similar problems when wiring something in wire parameteres, to an object that is linked to another object). Hope you understand me. Thanks in advance Edited February 7, 2013 by remilanza Link to comment Share on other sites More sharing options...
Scott Schroeder Posted February 7, 2013 Share Posted February 7, 2013 It makes semi-sense that your A object won't read a distance once it's linked. Think about your chain of events here. Your A object is now a child to the new object. In the sense of Max math, it's only moving the parent. You need to read the distance between your parent object and your B object and you should start to see the value move. In simple terms, read the position of the parent not the child in the link. Expressions are pretty literal in their functions. Link to comment Share on other sites More sharing options...
remilanza Posted February 8, 2013 Author Share Posted February 8, 2013 Thanks, yes I understand. But in my case the distance from the parent would not help me. But I guess if an object is moved by another object threw wire parametering and not linking, the position of the object will still be the "real" position. So I guess I can make it work that way. Link to comment Share on other sites More sharing options...
vojtechcada Posted February 11, 2013 Share Posted February 11, 2013 The easiest way to get coords in world space is getting the obj.pos or obj.transform. pos directly - you have to switch to script controller instead of expression controller and add the obj there. In some cases you can also throw in Expose TM helper instead to make things easier Adding wiring just to fix this is unnecessary and only adds another level of complexity, IMHO. Link to comment Share on other sites More sharing options...
remilanza Posted February 12, 2013 Author Share Posted February 12, 2013 Ok, I have never tried the script controller, or Expose TM. Will look into that. But how is script controller different from expression controller? I just oppened it now, it looked very similar. Link to comment Share on other sites More sharing options...
vojtechcada Posted February 13, 2013 Share Posted February 13, 2013 Basically, expression controllers are the oldest implementation, back before MAXScript was a part of the package, and are much faster than anything that uses MAXScript syntax (such as wire controllers or script controllers). However, they also have only a limited set of functions (and are also case sensitive) and you cannot make a scene object a variable and access its properties. For example, in script controller you can assign some object to obj variable and get its world position via obj.transform.pos or its position in parent space via obj.iNode.posInParent, and do advanced matrix transformations, access scene globals and so on. obj.transform.pos is generally safer as obj.transform computes a transformation matrix which includes ALL transforms including constraints. obj.pos should be okay provided you don't use constraints on the node, it functions as a direct property access, so $.pos.z += 10 will change node position, $.transform.pos.z will on the other hand only operate on the returned matrix so in order for it to work you'd have to do something like: nodeTM = obj.transform -- get it nodeTM.pos.z += 10 -- change it obj.transform = nodeTM -- set it Link to comment Share on other sites More sharing options...
