rhlkvr15 Posted February 8, 2013 Share Posted February 8, 2013 good Evening Forum, I have a scene with building and lots of vegetation around it......and i want to render a walk-through of it..... anyone here know how to add AO (in indirect illumination tab - VRay) for only the building. I want to exclude the trees from AO. I Dont want to render AO in separate pass and use in postproduction.... Thank You..... Link to comment Share on other sites More sharing options...
Andres del Castillo Posted February 8, 2013 Share Posted February 8, 2013 Hi, Rahul I recommend you Vray dirt http://www.spot3d.com/vray/help/150SP1/vraydirt_params.htm Good luck Link to comment Share on other sites More sharing options...
Scott Schroeder Posted February 8, 2013 Share Posted February 8, 2013 Use the Vray Dirt map combined with a Vray Comp texture (or RGB Multiply) on the materials for your building only. You'd take the dirt and multiply that onto your, for example, brick texture. Though really this is beyond better done in post. There is never a case that I can think of that you'd want to bake in your AO. Link to comment Share on other sites More sharing options...
rhlkvr15 Posted February 9, 2013 Author Share Posted February 9, 2013 thanks Andres...and Scott for the useful information...........thanks guys.... Link to comment Share on other sites More sharing options...
azharkazi Posted February 10, 2013 Share Posted February 10, 2013 good one http://www.archdez.com Link to comment Share on other sites More sharing options...
