network rendering problem
mzex
Hello!
I have two computer i5 2500k and i7 3930k.
I set a scene on i5 and all the data (project and textures) are saved on i5's HDD and is linked to my project through network drive. My drive E: on both computers is mapped as network drive, so it has letter Z and all textures have network path (Z:\projekti/...)
When I render only on i5 everything is OK.
When I render on i5 as master and on i7 as slave everything works.
If I open that file on i7 through network drive (nothing is saved on i7's hdd) everything is rendered correctly.
If I open project on i7 (still nothing is saved on i7's HDD) and add i5 as render slave I have problem. Everything rendered by i5 has no textures. Somehow i5 forgets to load data.
v-ray I use is 2.2 in max design 2012.
What should I do?
I have found answer here:
http://www.emailsignature.eu/phpBB2/how-to-get-a-unc-path-name-t341.html
and one thing to note is that path should look like:
\\server name\disk drive\directory name\...
at first my mistake was that I put : after e. it looked like this:
\\svejedno\e:\projekti\...
this hasn'e worked.
sythax that worked:
\\svejedno\e\projekti\...
Now I will test it on other comp.
