Vray render pass weird outline -help!
john2000
Hello,
Could I please get some help working out what this weird outline is.
This vray render pass was brought into photoshop cs6 extended.
As soon as I added a blend mode this outline appeared.
I thought that I might have tunes turned on, but no affects are on.
Please help - have a deadline.
Thanks
can you clarify what "pass" are you talking about? did you use Edge Text?
are you applying sketch filter or glowing edges inside Photoshop?
The image is very small, what it looks to me is like when you use glowing edges in photoshop, it draw like edges in your image, but still is utilizing every pixel data, so if you have a color difference in the same plane, it will draw a line between, but in your case is hard to say, if you don explain a little more.
