ryangroves Posted February 14, 2013 Share Posted February 14, 2013 Hi Guys, One of the pieces I am currently working on involves a large amount of rocks/pebbles that I have scattered using forest pack. I would like to use ivy generator or something similar just to get some vines running through the rocks, dead weeds etc. Just wondering if this is even possible to do/combine with forest pack geometry a or if there is any way around this?! Any help or pointers would be much appreciated! Cheers Link to comment Share on other sites More sharing options...
luthias42 Posted February 15, 2013 Share Posted February 15, 2013 you can use growivy. if you isolate the objects you want the ivy to grow before you place the "gwivy" object you should get what you want. Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted February 16, 2013 Share Posted February 16, 2013 along the lines that William is talking about, the ivy likely wont grow on a forest object. If you preview the FPP as a meshes at 100% you can use the snapshot tool to get a true mesh for the ivy to grow on. Good luck Link to comment Share on other sites More sharing options...
edgaro Posted February 16, 2013 Share Posted February 16, 2013 Well, I guess it shouldn't be a problem if you can export the geometry created in that software. Ivy gen supports triangle faces only, I read once, so take care of that part. Link to comment Share on other sites More sharing options...
ryangroves Posted February 17, 2013 Author Share Posted February 17, 2013 Thanks a lot guys, think that will work have only recently found out you can get the actual mesh out! Will give that a go in the next couple of days when I can get back around to it. Thanks again! Link to comment Share on other sites More sharing options...
