Tomoflog Posted February 14, 2013 Share Posted February 14, 2013 (edited) I am working on a residential exterior with a deadline soon approaching. I spent alot of time on this scene to get things the way i wanted and now fore some reason it will not render. It goes thru the FG process fine and renders to about 20-30 percent and then it just stops. If you try to render again it crashes. I have tried it on 2 systems so i know its not the PC. I tried deleting the high mesh trees and anything else that i thought might be screwing it up. I pretty new at this so don't rag on me too hard for my methods please. Here is a link to the file. let me know if it works or suggest another method. Thanks https://www.yousendit.com/download/UW13bGtIcHZGR0htcXNUQw I am using Max 2013 Win 7 64 I7-3770k 16gb ram forest pack lite 396 for my grass. Mental Ray w/ mr daylight system. I also have a couple evermotion trees in the scene Oh ya, it will render on a low resolution with high image precision or high res with low IP... Edited February 14, 2013 by Tomoflog Link to comment Share on other sites More sharing options...
cg_Butler Posted February 15, 2013 Share Posted February 15, 2013 I'm afraid I can't open it! Only MAX 2012. :-( Link to comment Share on other sites More sharing options...
Devin Johnston Posted February 15, 2013 Share Posted February 15, 2013 Unfortunately I'm using Max 2012 as well but why don't you try merging the entire scene into a new file that may help. Link to comment Share on other sites More sharing options...
Tomoflog Posted February 15, 2013 Author Share Posted February 15, 2013 Thanks for the replies guys. I have tried merging and xreffing and ended up with the same problem. I think I am all set now though. I selected my grass and a few other objects i needed and saved them as a new scene file. Then imported those into a fresh model of the house. No problems so far. I am still curious to see what is causing the problem or if maybe anyone else has encountered this. If anyone is bored and feels like downloading a trial 2013 max to open the file then please do. You would also need Forest pack lite. Thanks again! Link to comment Share on other sites More sharing options...
Tomoflog Posted February 15, 2013 Author Share Posted February 15, 2013 Here is a an Image after some work in PS. What do you guys think. I could really use some constructive ctiticism from someone besides my wife! Link to comment Share on other sites More sharing options...
Devin Johnston Posted February 15, 2013 Share Posted February 15, 2013 It looks good but a little washed out to me, maybe some contrast and saturation would help. Link to comment Share on other sites More sharing options...
