How to correct black dots!!
hamidhoky
I dont see the black dots. Still its a nice render as it is. Just use the curve adjustment tool in the frame buffer to add the depth to it or you could go to photoshop and work on it a little bit more. As it is, its not bad at all even without the render passes :)
Really no one doesn't know what to do?
Calm down! Have some patience for goodness sakes. You waited all of an hour to start bumping your thread.
Plus your problem description doesn't match your render. Black dots? What black dots? If you are seeing black dots in your white areas and we aren't, have you cleaned your monitor lately?
Your scene is too washed out white because you are probably double correcting your gamma by working in an incorrect gamma workflow.
