Night rendering preset
filipd
I'm pretty sure there are plenty of how-to's here: http://www.cgarchitect.com/features/category/making-of Though, of course, you'd actually have to do some work and not get a spoon fed solution. And, hey look, they give the settings to use to! Jeff and the artists don't put these making of articles out there to improve their health or writing skills.
You really need to do this by yourself. You can ask questions and ask for feedback. But by and large, you’ll figure them all out for yourself by working. You know, actually creating art. And, yes, failing at times. But failing just shows you where you need to improve. Stop trying to jump 5 years in the process of becoming an artist by just using plug and render solutions. You have to do the work yourself and it takes time to learn. Shocking I know in this age of I want everything 10 seconds ago.
Please read:
http://www.noahbradley.com/blog/2011/stop-whining-start-working/
what scott said
or
put a blue ambient light in (i heard from an architect once that nighttime is in fact BLUE not BLACK - also at night everything must be visible and nighttime is for criminals not buildings)
then if ur still following
put in warm temperature lights where lights would be
press render
apply a curve, some fog a soft glow here and there
bang it out and send the invocie
Thanks guys. I have already read lots of tutorials and set ups for vray. I tried experimenting with:
-night HDRI image
- low intensity sun
- blue light
- blue global lighting
But they all have different problems. Mostly there are bad shadows and grain. I have set a high end preset with lots of samples and subdivs with good DMC.
So I am looking for a rps because I can't do it.
-night HDRI image
- low intensity sun
- blue light
I'd take a look at these making of and compare your settings: http://www.cgarchitect.com/2013/01/the-making-of-tea-houses and http://www.cgarchitect.com/2012/11/the-making-of-cubus-house
Like Sajid mentioned, we can really help you if you post your image as well as your vray render settings. You need to build your own render preset. You must learn why you are setting things the way they are so you will know how to avoid noise in the future.
What you need isn't a render preset, what you need is to get your lighting right. Render settings are the same, day or night - you simply need to make sure you get the right balance between the light & dark, cold & warm tones.
Use plenty of reference photographs. Use Kelvin colour temperatures to get you in the right area when it comes to light colours. A decent starting point for indoor lights is around 3500 to 4000 kelvin, then counter it within the camera settings, thus creating a realistic contrast between outdoor & indoor lighting.
Edited by Macker
