abmitalia Posted February 24, 2013 Share Posted February 24, 2013 Hallo again. Long time that I didn´t posted . I come back with a question. I´m rendering a scene where the quality of the image used as background image as environment is pritty good. Rendering out the scene the backgrond appears with a nois quality and so the scene looses reality. How can I reach, that the rendered background image has the same quality as the original background. Thanks a lot abmitaly - Ralf Link to comment Share on other sites More sharing options...
Scott Schroeder Posted February 24, 2013 Share Posted February 24, 2013 What size are you rendering and what size is your image background? If you are rendering to a bigger size than your image background, you will see loss in quality. The bigger the difference, the bigger the loss in quality. Link to comment Share on other sites More sharing options...
abmitalia Posted February 25, 2013 Author Share Posted February 25, 2013 Dear Scott. Image is the same size as render size. Link to comment Share on other sites More sharing options...
abmitalia Posted February 25, 2013 Author Share Posted February 25, 2013 Ok . Solved my problem by rendering without background and saving in .png, even if the after work is pritty hard to do, eliminating the margins, which tend to assume the gamma backgrounf color. Greatings RK Link to comment Share on other sites More sharing options...
