Problem with VRay for Skp options
synartect
I'm using Skp 8 and VRay 1.48.91 in windows 7 OS.
The problem is there are some settings in VRay options that uneditable. For example:
- I can't change the value of size_multiplier and sky brightness in Texsky in GI and BG environment.
- I can't change the value of Primary Engine in Indirect Illumination.
- I can't change the value of DMC Sampler and Color Mapping.
And there some more options that uneditable.
Is there anyone that can help me please? I've tried reinstall the Skp and VRay, but nothing change, it's still the same.
  • 2 weeks later...
  • 1 month later...
you can't adjust this if you are using SunLight System under General Tab of TexSky - the settings will adapt the Sunlight Parameters. If you change the Sun System to None on General Tab of TexSky, then you can now adjust the parameters that you have stated.
As for the other queries, im not sure about it, because on my settings, it all adjustable. maybe upgrading will do as quoted by Sir valerostudio.
Good Luck
Edited by ronel
