convert FormZ into acad or VIZ ??
vizwhiz
(maybe we need a Forum for software file conversion ??)
how do you get a 3d model from FormZ into autocad 2004 or VIZ 2005?
we have a Client who keeps sending us PDF of EPS files of a Theatre bldg
that i end up bringing into autocad (scaling up etc) and Then Tracing over
to get some approximate Elevations before trying to reverse-engineer the 3d bldg
back into cad and VIZ for rendering (when Then goes into a 2d PS collage)
There has got to be a more direct way to do This, i Think
The bldg keeps changing and it is way too Time consuming
to keep re-sketching the Elevations to modfiy the 3d mass modeling
any Ideas??
i know This kind of falls into The Cracks in between softwares
so maybe There could be a SOFTWARE CONVERSION FORUM
for Ideas etc Things like This
hey it is only Momday am and i havent had coffee yet
so This is my one big Idea for the entire week
(since i am NOT familiar with FormZ i am asking here in the VIZ area)
Thanks
Randy
"a Mind is a Terrible Thing to waist." If you dont Mind it doesnt Matter
Hi,
As a long time FormZ user I can say that one of its strengths is that it can read and write almost any file format. I often use 3ds or dwg as required by the nature of the work. See below for a list of formats FormZ can use and take your pick.
Good Luck,
O
3DStudio
ArtLantis
DWG
DXF
FACT
IGES
Lightscape
Lightwave
OBJ
RIB
SAT
Shockwave
W3D
STEP
STL
3DGF
3DMF
VRML
hey Fernando
Thanks for the Tip and Technique
i (was) mis-informed we do have Illustrator here at work
so i will be able to try That later sometime as soon as Time permits
Thanks again
Archidork
can you give me a "brief" list of the "exact" commands to "saveas" to Autocad
i am sure This is fairly straight forward but i got to send along Instructions
to an architectural Principal who does not do This on a day-to-day basis
Thanks for your patience Time and consideration
Randy
