isolate selection
Hi,
If you are using Max 2012, yes that was one of the crazy bugs of Max 2012, all what you have to do is, click the same object and select isolate again, the window will pop and then you can un-check to show all the other mesh.
Now if you are using Max 2013, that isolation windows was replaced for a littly-bitty small reddish light bulb at the bottom of the screen, about the middle under the time line, just chick that icon and it will toggle isolation on or off.
