tomelcott1 Posted March 10, 2013 Share Posted March 10, 2013 Hi Everyone, So iv used a directional light to create awesome "volume light" in a scene before, like rays of light shining in through a window. Since i did that i now use the V-Ray Physical camera, and i cant seem to get the same effect, my "Fog" just renders like dark grey? Has anyone had this problem? V-ray Camera settings all default, and Volume light effects all default... Image below of "Dark God Rays" Link to comment Share on other sites More sharing options...
erikeekelen Posted May 2, 2013 Share Posted May 2, 2013 Have u solved it? i have the same problem, somehow the volume light renders grey.. Please reply, cant find anything on google and stuff. cheers Link to comment Share on other sites More sharing options...
LaBelette Posted March 17, 2014 Share Posted March 17, 2014 similar problem here, my volume fog (in mental ray but) renders also grey at the distance, even though its color is set white... cant figure out why.. Link to comment Share on other sites More sharing options...
Nic H Posted March 17, 2014 Share Posted March 17, 2014 is doesn't work properly with vray - use the vray environment fog or you can render it as a separate pass using a standard cam or vray cam with exposure off its a bit irritating as the volume light was more flexible and faster than Vray Env Fog Link to comment Share on other sites More sharing options...
Tim Nelson Posted September 16, 2014 Share Posted September 16, 2014 is doesn't work properly with vray - use the vray environment fog or you can render it as a separate pass using a standard cam or vray cam with exposure off its a bit irritating as the volume light was more flexible and faster than Vray Env Fog Very irritating. I was just trying to use volume light today to create a glow over a lightbulb. It works ok on low intensity and against a dark background, but as soon as you try to crank it up it goes gray. Very lame. Link to comment Share on other sites More sharing options...
Chris MacDonald Posted September 17, 2014 Share Posted September 17, 2014 That's because it's not a VRay light. It's no different to trying to get Mental Ray to render VRay lights. It isn't going to work properly. Like Nicnic said, use the VRay Environment Fog for volumetric scattering. The difference being that the Vray Env Fog actually scatters light through a volume rather than approximating it, so more realistic results are achievable with it; at the cost of render & setup times. Link to comment Share on other sites More sharing options...
elipan Posted September 18, 2014 Share Posted September 18, 2014 Is there a way to make only some dense "god rays" visible without greying the whole image? I've tried via render elements but I don't know how to assemble it in photoshop.. Link to comment Share on other sites More sharing options...
Chris MacDonald Posted September 18, 2014 Share Posted September 18, 2014 In photoshop you set the blending mode to "Screen" Link to comment Share on other sites More sharing options...
