Scatter problem
branimirpejnovic
I'm trying to create grass trough scatter but keep heading into some problems.
First i have modeled couple of grass then saved them so i can use them later.
When i merge grass previously created, in scene and use scatter on created plane it scatters outside of the plane. When i create any kind of other object it scatters correctly on the plane.
I tried aligning and reseting pivot but with no luck.
Does anyone knows what is an issue with merging outside object and how to correct it.
Thanks.
Yes it is.
The problem seems to be with applying multiple objects to scatter.
When i use just one object it scatters fine but when i group them and collapse them, it creates plane that is in offset of original and scatters the object on some kind of plane but it has offset from created and original plane.
