gediminasstasaitis Posted March 24, 2013 Share Posted March 24, 2013 Hey everyone, Does anyone know how to make 3d diagrams like this? Seems to be some sort of 3d programme that you can export vectors with and the extra touch on illustrator. The thing i don't know how to do is how do you export the hidden linework (the rooms, stairs etc. inside). Accuracy, proportions of the inside, outside spaced are also quite important. Your help and info is greatly appreciated. Link to comment Share on other sites More sharing options...
H A Posted March 25, 2013 Share Posted March 25, 2013 I use a combination of SketchUp and Illustrator when doing this kind of work. You'll find loads of tutorials on the subject. Link to comment Share on other sites More sharing options...
ravipatel Posted March 25, 2013 Share Posted March 25, 2013 Hi, Gs I cant Understand Your question Properly. But If U want This Types Of OutPut In 3d software Its Possible Looking Like This By Some Tricks.. If u Use 3dsmax so Use Blend Material .And Take Two Types Of material . One Is Ink-Paint And Other One Is Standard. In standard material give Opacity like 50 around and Overall Blend Material Mix Amount also 50.. and apply,render and u will get yr result Link to comment Share on other sites More sharing options...
M V Posted March 25, 2013 Share Posted March 25, 2013 SketchUp Pro will export vector art like this. Link to comment Share on other sites More sharing options...
gediminasstasaitis Posted March 25, 2013 Author Share Posted March 25, 2013 The tip sounds useful thanks Ravi Patel, although i think i would get raster image which i would need to trace over later, which is fine for less detailed things. Sorry about the question, I'll try to clarify it, the main question is how do you make accurate models and export transparent vector lines so you can then later edit them in illustrator for clarity. I tried to export 2d pdf images from sketchup, but the only ones that work are wireframe, which when you have a lot of lines you get confused..when you try to export hidden line: back edges or x-ray (which is more clear) it doesn't export the hidden lines, just the mass that you see, that's my main problem..maybe its playing around with the settings? Are there any tutorials on this because i searched the web a bit and cant seem to find anything that would be spot on. Link to comment Share on other sites More sharing options...
H A Posted March 25, 2013 Share Posted March 25, 2013 Export 2 eps files; one with the shaded model and one with the wireframe model. Combine these two in Illustrator and you have the best of the both. Link to comment Share on other sites More sharing options...
bilyanajul Posted December 12, 2013 Share Posted December 12, 2013 Hello everyone, I've got a similar question based on a bit different example. I would like to ask you, how could one make such diagrams with these nice soft shadows, soft material, illumination color effects, color blending, transparent arrows, etc. Any suggestions would be greatly appreciated! Thank you in advance. Link to comment Share on other sites More sharing options...
daryljones Posted January 1, 2014 Share Posted January 1, 2014 Adding transparent arrows, colour overlays etc is pretty simple in photoshop. Link to comment Share on other sites More sharing options...
Dejan Sparovec Posted January 2, 2014 Share Posted January 2, 2014 I would probably do a simple render with ambient occlusion or just a skylight and color it and add the details in photoshop. Outlines are simple to achieve with vray toon effect. Link to comment Share on other sites More sharing options...
