MultiScatter problem
bertjow1
Hallo everyone,
I got small problem with multiscatter, when I put some basic object like box or teapot, multiscatter generated them correctly on the surface. But when I am trying to put some mesh like grass blades created from splines - multiscatter generated them under surface..
Teapot and grass blades have the same basic points Z=0.0 so I have no idea what is wrong.
Could anyone help me with it
best regards
Hello,
Ok i setup it using axes, it works more or less.. just need some adjustments in 3 axis
but there is another problem.. i created some grass blades - group them to one object, put editablepoly modyfier, setup base point on Z axie to 0.0 (didn't convert to proxy yet) Then using blades as multiscatter object I tried generated them on surface but.. he is generate only one blade... why?
After render grass also doesn't look to good.
