stepanpolokov Posted March 25, 2013 Share Posted March 25, 2013 hi I have problem in vray 2.0 for max .. ok I start to using VFB for rendering .. and if I want to save this image from VFB and save it the output image (jpg or tiff) looks so different than the image in VFB (without all changes and effect what I put in VFB) How I can save the same image as I have in VFB without the printscreen ?:-) Link to comment Share on other sites More sharing options...
notamondayfan Posted March 25, 2013 Share Posted March 25, 2013 The change in colour is probably down to your gamma settings and how you have your VFB configured. Also when you save the image, are you using the save icon or using the "Save seperate render channels" in the render setup? Dean Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted March 25, 2013 Share Posted March 25, 2013 I am pretty sure it is a gamma issue, can you tell us about your color mapping values and how you set up your gamma in MAX? Link to comment Share on other sites More sharing options...
stepanpolokov Posted March 25, 2013 Author Share Posted March 25, 2013 I have defauld mamma in max but i thought now it is working in vray and it is on tom of the max settings... ?... I save it by the save image button n midle of the tom VFB ok if I changed gamma settings in max and after that I want to save images with and without click button down coner in VFB ... i mean LUT, exposure correction and etc .. it make different images ? Link to comment Share on other sites More sharing options...
Mario De Achadinha Posted March 26, 2013 Share Posted March 26, 2013 Hi Had same issue for over a year, very simple solution make all ur gamma to 2.2 except the output put that on 1.0 then on your vray frame buffer make sure srgb is off. Save as png find that is best quality, will be the same. Test out let us know. Mario Link to comment Share on other sites More sharing options...
