Vray Sun+Domelight and displacement
bartjole
Hi, im working with 3ds Max for a bit now and i'm having some troubles.
I'm terrible modeling in Max, so i make everything in Sketchup.
So i followed this nice tutorial of Peter Guthrie:
http://vimeo.com/11134608#
Still i have not managed to get a nice lighting. This is the result:
Don't pay any attention to the materials, it's far from done.
With the following options:
Another problem is the grass surface. I'm lazy ;) so i'm using the Autograss plugin. It's ok for me, but a bumpy surface would be nice. Thats possible in the options of a plane (segs+displace), but my imported mesh does not have these opions.
Any solutions will be very welcome!
Greets,
Bart (Architecture Student)
Are you using a VRay Camera or the Environment Exposure Control? Whichever it is, it looks like you might need to adjust the exposure settings.
There was also a follow-up tutorial that Peter posted a little over a year ago that explains using the gamma adjustment to produce more contrast in the lighting from an hdr/exr:
http://www.peterguthrie.net/blog/2012/02/hdri-lighting-workflow/
This could eliminate the need for using a VRay Sun.
Are you sure all your render settings are correct? Also, there seems to be some unknown light source in your scene. The edge of your shadows seems a bit to sharp to be generated from an HDRI. Maybe there is a conflict in your lighting somehow?
Adding a noise modifier is an option for your ground mesh, to just add some random bumpiness. Or do you mean you need more segments?
