thorsten hartmann Posted April 19, 2013 Share Posted April 19, 2013 Hi Guys, i have update Render Optimizer V3 for 3dsmax2014. Certainly work this Script with 3dsmax2012-2013. download Render Optimizer V3: http://www.infinity-vision.de/page/ro_menue What is NEW... - optimized for 3dsmax2014 - Importance Sampling - Ambient Occlusion GPU - MILA Options have fun! mfg hot chip Link to comment Share on other sites More sharing options...
thorsten hartmann Posted June 22, 2013 Author Share Posted June 22, 2013 Hi Guys, it give a new Update of Render Optimizer V3 with many Bug fix. At now works GPU AO. Render Optimizer generate a "GPU AO Render Element". The original workflow is from here: http://area.autodesk.com/blogs/garyd/gpu-ambient-occlusion-ao-and-ibl-w-mental-ray-in-3ds-max-2014 download Render Optimizer V3 here: http://www.infinity-vision.de/page/ro_menue have fun! mfg hot chip Link to comment Share on other sites More sharing options...
blank... Posted June 29, 2013 Share Posted June 29, 2013 Thank you! Link to comment Share on other sites More sharing options...
thorsten hartmann Posted October 20, 2013 Author Share Posted October 20, 2013 Bug Free !!! Render Optimizer V3... Erik Schneller have give me Feedback of some Bugs. All GPU AO is fixed + irradiance map file for network works now 100%. The last Bug was a never ending Story. download Render Optimizer V3: http://www.infinity-vision.de/page/ro_menue have fun! mfg hot chip Link to comment Share on other sites More sharing options...
thorsten hartmann Posted October 27, 2013 Author Share Posted October 27, 2013 I Guys, i have added a new features "luminance weight on/off) to fix the 3dsmax 2014 "sample error cutoff" Bug. tread "sample cut error bug": http://forums.autodesk.com/t5/3ds-Max-3ds-Max-Design-General/Be-very-careful-Max-2014-Unified-sampling-error-cutoff-broken/td-p/4353043 download Render Optimizer V3: http://www.infinity-vision.de/page/ro_menue have fun! mfg hot chip Link to comment Share on other sites More sharing options...
blank... Posted November 21, 2013 Share Posted November 21, 2013 i have added a new features "luminance weight on/off) to fix the 3dsmax 2014 "sample error cutoff" Bug. Hello thorsten, it looks like your fix doesn't work. With luminance weight disabled i'm still getting this in mr message window, even though cutoff is set and locked at 0.005 samples error cutoff 0.00169673 0.000504565 0.005 Furthermore, try this: check "disable", now switch to any other tab on render optimizer, now switch back to Unified. "Disable" for luminance weight is again unchecked. Link to comment Share on other sites More sharing options...
thorsten hartmann Posted November 21, 2013 Author Share Posted November 21, 2013 (edited) Hi Dario, when have you download this script. You are right it was a Bug, but i have fix it for some days. Please download again from the same Link. last update was 13.11.2013 11:29 it must work. cheers thorsten Edited November 21, 2013 by thorsten hartmann Link to comment Share on other sites More sharing options...
blank... Posted November 22, 2013 Share Posted November 22, 2013 You are right! Thank you once more Link to comment Share on other sites More sharing options...
TomD_Arch Posted February 8, 2014 Share Posted February 8, 2014 Looking to get some help I have downloaded and installed 3ds Max Design SP3 and the latest version from your site. When I check the box for AO GPU Enable the render stops immediately and I get this: "GPU 0.8 50 MB fatal 871109: runtime exception 0xc0000005: access violation GPU 0.8 50 MB fatal 871109: runtime exception 0xc0000005: access violation MSG 0.0 50 MB error: A Fatal error occured while rendering with NVIDIA mental ray. This render will abort. NVIDIA mental ray is now in an unstable state and cannot be used any more for this session. To render again with NVIDIA mental ray, please restart 3ds Max. The error is : GPU 0.8 50 MB fatal 871109: runtime exception 0xc0000005: access violation" I am just learning to use this plug-in. I have looked around on the NVIDIA site and found ref to a video you posted on AREA so when I use the AO-GPU string fromt he video I get this: "GPU 0.8 41 MB fatal 871109: runtime exception 0xc0000005: access violation GPU 0.8 41 MB fatal 871109: runtime exception 0xc0000005: access violation MSG 0.0 41 MB error: A Fatal error occured while rendering with NVIDIA mental ray. This render will abort. NVIDIA mental ray is now in an unstable state and cannot be used any more for this session. To render again with NVIDIA mental ray, please restart 3ds Max. The error is : GPU 0.8 41 MB fatal 871109: runtime exception 0xc0000005: access violation" Any help would be appreciated Link to comment Share on other sites More sharing options...
thorsten hartmann Posted February 9, 2014 Author Share Posted February 9, 2014 Hi i have test here on my machine, and no problems. I use 3dsmax Design 2014 + GForce GTX 780. Can you upload a demo scene. mfg hot chip Link to comment Share on other sites More sharing options...
TomD_Arch Posted February 15, 2014 Share Posted February 15, 2014 After further investigation I am discovering this probably has to do with the graphics card I have in my machine. It is NOT an NVIDIA Quadro with CUDA gpu. Ergo: the AO will have to be left alone until I can get that graphics card. Link to comment Share on other sites More sharing options...
