Vray Proxies strange behaviour?
jonasthomas
Hello,
I have been trying Vray proxies for the first time. I have made this grass patch into one single object and even pressed on the "reset xform" button. After rendering I had some very strange results. In the images below you can see the original grass patch (not a proxy) and the proxies I have made. The proxies appear to be darker and when I zoom in, these little black squares appear. Does someone have any idea what I am doing wrong?
Thanks in advance!
UPDATE: I thought it had something to do with the version of Vray, so I uninstalled 2.4 and I installed 2.3 again. At first it seems to work, but then I discovered that when you look at it from above, there seems zo be no problem, but when you look at it from the side, there appears a difference in material again. You can see the darker grass patch in the image below. I don't get it. :-( What am I doing wrong?
