dostmeymo Posted April 23, 2013 Share Posted April 23, 2013 Hello i have a problem with saving the image after render in frame buffer . after i save , the color of picture is became more light . i tried all files type and i could not fix it . i hope some one help me thanksss Link to comment Share on other sites More sharing options...
Chris MacDonald Posted April 23, 2013 Share Posted April 23, 2013 You're not using linear workflow? Link to comment Share on other sites More sharing options...
dostmeymo Posted April 23, 2013 Author Share Posted April 23, 2013 do you mean in color mapping ? yes i'm using linear type Link to comment Share on other sites More sharing options...
Chris MacDonald Posted April 23, 2013 Share Posted April 23, 2013 No, I mean your gamma setup. Are you using 2.2 gamma? Link to comment Share on other sites More sharing options...
dostmeymo Posted April 23, 2013 Author Share Posted April 23, 2013 Yes . Sure Link to comment Share on other sites More sharing options...
Chris MacDonald Posted April 23, 2013 Share Posted April 23, 2013 I just noticed you don't have "sRGB" ticked in the framebuffer. Provided you're working with the same settings as the ones I posted, the image you're saving out is actually the correct one - you've been working in the VRay framebuffer viewing an image with a gamma of 1. Link to comment Share on other sites More sharing options...
dostmeymo Posted April 23, 2013 Author Share Posted April 23, 2013 OK .. i tried to change my gamma in preference setting . and its saving correct now . but of course we should re change our color mapping till we get the correct color . any way . The problem was fixed . THANK You very much Chris MacDonald .... Link to comment Share on other sites More sharing options...
Chris MacDonald Posted April 23, 2013 Share Posted April 23, 2013 No problem. Link to comment Share on other sites More sharing options...
bindunarayan Posted April 24, 2013 Share Posted April 24, 2013 I should say that this is one common problem that most of the designers would face as I have come across the same problem often times. Thanks for that easy solution. Link to comment Share on other sites More sharing options...
dostmeymo Posted April 30, 2013 Author Share Posted April 30, 2013 Guys.. the best result for materials it's always with gamma 2.2 (for me) and i can not use 2.2 gamma coz i can not have the correct colors when i save it with frame buffer . is there any other solution to have the correct colors after save the frame buffer without changing the gamma ???? Link to comment Share on other sites More sharing options...
Chris MacDonald Posted April 30, 2013 Share Posted April 30, 2013 I'm not entirely sure what it is you're asking. Are you using the sRGB button in the VRay Frame Buffer? Because that will show you what your image looks like with a gamma of 2.2 applied, without it on you are probably setting all of you lighting, etc wrong. Link to comment Share on other sites More sharing options...
