jackbird Posted May 8, 2013 Share Posted May 8, 2013 (edited) Pricing for 5 3770K headless mini-itx render nodes w/ 16GB (20 physical cores) is basically the same as for 3 3930K headless micro-ATX render nodes w/ 32 GB (18 physical cores). Is there a clear difference in expected 3ds max rendering performance? Naively multiplying Passmark scores suggests the 3770Ks win by 25%, but I realize that's not render-specific. If not I'd rather have only three machines to power and maintain. EDIT: Someone replied (now deleted?) questioning the pricing. Here's my breakdown (all prices Microcenter retail unless noted): 3770K: $229.99 intel 3770K $94.99 AsRock H77M – ITX $89.99 Crucial DDR3 – 1600 (2 x 8 GB) $54.99 Sandisk 64GB SSD $54.99 Corsair 430W PSU (80+ Bronze) $44.99 Cooler Master Elite 120 Mini-ITX case $134.98 Win 8 Pro x64 (amazon) $704.92 per node $747.22 with sales tax -$10.00 Corsair PSU rebate -------- $737.22 total per node $3,686.08 For 5 nodes 3930K: $499.99 intel 3930K $209.99 AsRock X79 Extreme4 LGA 2011 micro ATX (newegg) $89.99 Crucial DDR3 – 1600 (2 x 8 GB) $99.99 Crucial DDR3 – 1600 (2 x 8 GB) (price difference is a motherboard bundle deal) $54.99 Sandisk 64GB SSD $54.99 Corsair 430W PSU (80+ Bronze) $36.99 Fractal Design Core 1000 mATX case $134.98 Win 8 Pro x64 (amazon) $1,181.91 per node $1,252.82 with PA tax -$10.00 Corsair PSU rebate -------------------------------- $1,242.82 total per node $3,728.47 For 3 nodes – 18 cores Edited May 8, 2013 by jackbird Link to comment Share on other sites More sharing options...
Dimitris Tolios Posted May 9, 2013 Share Posted May 9, 2013 Assuming that the IGP for both is the same (which is not, 3770K is ~10% faster per clock): Aggregating MHz: 3930K = 12 threads @ 3200MHz = 38,400 MHz / CPU * 3 = 115,000 MHz 3770K = 8 threads @ 3400MHz = 27,200 MHz / CPU * 5 = 136,000 MHz Without correcting for IGP, the 5x 3770K nodes would be 18% faster than the 3x 3930K nodes. Assuming a 10% IGP performance gain clock per clock which is a safe assumption in most Ivy bridge vs Sandy bridge scenarios, the 3770K set will be 30% faster. I would not go for itx, despite the fact that I love the format, simply to have the 4x dimm slots and the capability for 32GB max Ram - even if you think that initially 16GB will be enough. H77 mATX boards are also around $20-30 cheaper than ITX equivalents. The Core 1000 is a great case for the price. If you end up with 3930K (or any s2011 CPU), remember that you need to account for CPU cooler - non is included. Link to comment Share on other sites More sharing options...
notamondayfan Posted May 9, 2013 Share Posted May 9, 2013 Don't forget other things to consider.... Power usage - will running 5 nodes be more expensive than 3. Management and maintenance - 3 nodes will be easier to maintain and update, and also take up less physical room. Reliability - having 5 nodes would give more reliability, as if 1 goes down, your down 20%, where as with 3 nodes if you lose 1, then you're down 33%. If it were my choice, I'd got for 5 nodes, as Dimitris calculates it will be faster, and more reliable too. Dean Link to comment Share on other sites More sharing options...
jovicazivkovic Posted May 9, 2013 Share Posted May 9, 2013 (edited) Do you need separate graphic if you go with Intel 3930K? On the intel site it says that 3930k doesn't have graphic? I am also looking for custom DIY render farm for maya / max ... Edited May 9, 2013 by jovicazivkovic Link to comment Share on other sites More sharing options...
jackbird Posted May 9, 2013 Author Share Posted May 9, 2013 I would not go for itx, despite the fact that I love the format, simply to have the 4x dimm slots and the capability for 32GB max Ram - even if you think that initially 16GB will be enough. H77 mATX boards are also around $20-30 cheaper than ITX equivalents. Would you endorse a Biostar H77MU3 motherboard? That's the only Micro-ATX 32 GB H77 board Microcenter carries that's less expensive than the Mini-itx AsRock. Link to comment Share on other sites More sharing options...
Dimitris Tolios Posted May 10, 2013 Share Posted May 10, 2013 Would you endorse a Biostar H77MU3 motherboard? That's the only Micro-ATX 32 GB H77 board Microcenter carries that's less expensive than the Mini-itx AsRock. I have no personal experience with Biostar for ages. The board appears to have decent reviews in Newegg (only 2x in amazon, both 5/5). In general I haven't seen any major complains with Biostar products. Tbh the biggest complains are coming from more premium brands, probably cause the buyers might have more unrealistic expectations and/or certain boards are used for reckless overclocking etc. This board will have very little stuff you can tweak and harm (just what you need). Depending on the price difference though, I would spare $20 here and there if I could get a better board, yet there aren't many options. The only one available at that biostar's range is a Gigabyte GA-B75M-D3H @ Amazon.com. I don't think it will be better really. Link to comment Share on other sites More sharing options...
Mario Pende Posted October 12, 2013 Share Posted October 12, 2013 Has anyone made any direct comparison between the 3930 and 3770? WOuld definetly like to hear waht where the rendering times for the same scene. Anyone has maybe a side by side comparison? Thanx Link to comment Share on other sites More sharing options...
