Shadows and bakground problem in max6
Alvaro Ram.
hi alvaro, first of all congratulations for your images, you made a great progress...
About the reflection, if you're using a vray map you need to set the environment map in the vray map settings with another image different as the environment try with a only sky image (if you leave in NONE, will going to use the current environment image)
In spanish:
loco, pone en el cuadro de dialogo del vraymap donde dice environment una imagen diferente seria bueno un cielo solo
Esto quiere decir que cuando el material no tiene nada que reflejar va a usar esa imagen (por defecto la imagen de fondo)
SAludos!!
