Vray distrubuted problem Black gray Boxes in the final render
kishore3d
Hai friends ,
can anyone please kindly help solving the problem..
Vray distributed renders Black gray Boxes in the final render ..
i had shared the complete project into a new Mapnetwork drive and shared it into network..but i still cant understand why im facing the problem
please kindly find the image of render attached
Even a tea pot with ies light gets the same problem :(
Regards
kishore
I've seen issues like this happen, and usually it's one of 2 problems:
If the materials don't seem to be rendering at all, it could be that you're not using UNC paths to your assets (materials). Set all paths to UNC, and make sure all computers in your network have access / permission to use those resources.
If the material seems to be rendering, but it's not the right shade: make sure your gamma settings are the same on all the computers in your network. I've noticed that DR slaves don't adopt the gamma settings of the file you're rendering, so you have to manually make sure the settings are consistent.
  • 6 months later...
